curtain by opacity map = disaster ! ?
  • curtain by opacity map = disaster ! ?
    i try to be close to real world and create curtain by real fabric opacity map
    the result is lotsss of noise that cant be clear
    i guess is because all the rays need to travel thru the tiny holes and get lost
    even if i put portal outside and exclude the curtain is still not go well
    what to do? 2 side material maybe look ok from far but not for close up
    any great solution for curtain?
    Try setting the VRayMtl opacity mode to "clip" and see if it helps.
      yes! its really work. the time is cut in half in the same amount of noise
      thanks vlado!
