vrayDenoiser crash
  • vrayDenoiser crash
    if I use the denoiser render element in a 1k rendering everything is good, but if I use it in a 6k rendering it crashes as soon as the denoiser starts... and it reboots the computer.
    I use the latest build and a gtx 980ti with the newest driver.
    before I had a gt 640 in this computer and it worked well but very slow, so it has to do with the new graphic card.
    any ideas?
    thanks
    themaxxer
    Pixelschmiede GmbH
    www.pixelschmiede.ch
    By latest build do you mean the latest official build, or some of the nightly/stable builds?
      the latest official build.
      thanks for reply.
      Pixelschmiede GmbH
        This should be already fixed in the latest nightly-stable builds.
          ok try it, thanks.
          I have to update all my rendernodes... but hey if it's workinfg then.
          best regards
          themaxxer
          Pixelschmiede GmbH
            You can always turn off the hardware acceleration option... Might be slower but it will work.
              That's interesting and good to know. I've had crashes with denoiser too.
              Regards
              Steve
              My Portfolio
                We had a bug that we fixed there, so it will be better for the next SP.
                  I have installed the latest nightly now and it crashes like before with opencl enabled...
                  although it takes longer till it crashes, maybe after a minute of denoising it restarts the computer.
                  a funny fact is that I have installed the same card in my workstation and it worked flawless till I put the same card into my main rendernode, now I have this problem.
                  I have bought a new GTX 1080 for my workstation and this card works also fine. so if there a library needed, something to install, it's so strange...
                  it happens in all scenes, so I can't send a scene...
                  ps. without hardware acceleration it works.
                  best regards
                  themaxxer
                  Pixelschmiede GmbH
                    Can you tell the exact GPU model that is causing troubles, as well as the driver version ?
                    Best,
                    Blago.
                    V-Ray fan.
                    Looking busy around GPUs ...
                    RTX ON
                      it's a GTX 980 TI (strix) driver version 375.70
                      thanks
                      themaxxer
                      Pixelschmiede GmbH
                        thanks
                        themaxxer
                        Unfortunately it did not reproduce here.
                        Are you okay to setup a online session with our support with teamviewer, so we can log in and check what is going on ?
                        If yes, please write to support@chaosgroup.com with link to this thread to arrange appropriate time.
                        Thanks,
                        Best,
                        Blago.
                        V-Ray fan.
                        RTX ON
