Vray Light Lister window went missing
  • Vray Light Lister window went missing
    Can't find the Vray light lister. Not sure if it's not opening, or is opening somewhere but is off my monitors. Have done the usual windows tricks, like Cascade windows, etc. But it still doesn't show up. Any tips?
    Windows 7, Vray 3.4, 3dsMax 2016
    Thanks - Chris
    Try this
    http://mornestudio.com/ui4one_liners/
    Kind Regards,
    Morne
      hi morne,
      another one you could add is fix vray object properties etc. quads. mine disappeared again, grrr.
      i think i`ll have to delete my max settings again. ah 2016, you hunk of junk.
      cheers
      anthonyh
        Originally posted by anthonyh View Post
        hi morne,
        cheers
        anthonyh
        Try the light lister fix and see if it fixes it... let me know
        Kind Regards,
        Morne
          hi again,
          yup that did it, sorry i presumed it only did the light lister, like a numpty i didn`t check.
          it`s all back as it should be.
          many thanks
          anthony
            Morne,
            The Vray Light Lister has always been available in my Tools menu. And is supposedly open, it's just nowhere to be found. I ran your script anyway, but still no luck.
            Thanks though.
            Chris
              What if you bring back the Light Lister window in the monitor view?
              You can try this approach: make sure the windows is open and active. Then press Alt+Space, M, hold one of the arrow keys and move the mouse to bring the window in view.
                That worked! THANKS!
                  [QUOTE=Zdravko.Keremidchiev;n808114]What if you bring back the Light Lister window in the monitor view?
                  You can try this approach: make sure the windows is open and active. Then press Alt+Space, M, hold one of the arrow keys and move the mouse to bring the window in view.[/QUO
                  Thanks Man! You solved my problem.
                    Morne's kindly provided script only really runs "registervraymenus()", a function we distribute with the standard v-ray install and that you can type yourself into the listener to identical result.
                    Multi-monitor fixes to UI elements are of the kind Zdravko mentioned, where the window actually takes focus, or have to be provided by the tool maker where it doesn't (f.e. the VFB functions to reset its position.).
                    Lele
                    emanuele.lecchi@chaos.com
                    Disclaimer:
