Animated FOV not rendering correctly
  • Animated FOV not rendering correctly
    The animated FOV works in the viewport but not on the render. Is this a bug ? I've had this issue previously on other projects.
    Regards
    Steve
    My Portfolio
    Are you using the 3ds Max 2016 Physical Camera?
      I am yes.........
      Regards
      Steve
      My Portfolio
        I had this several times with the physical cam. (I like dolly zooms) I figured animated focal length instead works generally better.
        Also turning lens breath to 0 if rendering animations with a moving physical camera fixed some bugs for me.
        Putting a keyframe on every frame might help too. Especially if you render on more than one computer.
        Its not really a good choise for animation.
        Better go back to the vray cam.
        Loosing hours and hours of rendertime because the computers only rendered a bunch of useless waste isn't good for the blood pressure.
        German guy, sorry for my English.
          Luckily I have a small render farm so I can test these things prior to rendering the final version. I'm not using exposure so I may just go to the max standard camera and link it to the existing camera. Hopefully the max standard cam should be fine.
          Regards
          Steve
          My Portfolio
