Difference between RT gpu and Main rendering
  • Difference between RT gpu and Main rendering
    I have been rendering a scene in RT using gpu, I then go to render the high res image with the main render and things looks slightly different, materials aren't as black as they are in the RT for example. Does anyone know why this could be?
    Thanks
    It's hard to say exactly; it might be a bug, or some texture might render slightly differently. It would be best if you can send us an example scene to support@chaosgroup.com so that we can fix it.
      Hi Vlado,
      Thanks for the reply, sadly I cant send the file, the work is under a NDA. Once I am done I will set up another scene to replicate the issue and send it over.
      Thanks,
      Tarik
        Ok, thanks!
