As the thread title says, materials in Material Editor don't update while IPR is running. They, however, update accordingly in VFB itself. For some strange reason this only happens after running at least 2 IPR renders in a row. With the 1st IPR render for the current scene, materials update fine in Material Editor.
Another side effect of this problem is that even after you stop IPR, the materials in Material Editor don't update to show the changes made while IPR was running. Not even if you close Material Editor and open it again. The material preview are only updated when you change some setting in the materials after IPR is stopped or when you reload the scene. I can imagine if you've made changes to a lot of materials while in IPR, it will be a big problem to go and start changing their settings again just to force an update. In this case reloading the scene will be faster as a workaround but still is a pain. If one is careless they might think their materials look certain way by looking at the Material Editor when in fact they might render quite differently.
