how to convert physicalcamera max 2016 to vrayphysical camera in max 2014
  • how to convert physicalcamera max 2016 to vrayphysical camera in max 2014
    Hello, I need to render in max 2014 a scene from 2016 but I do have a message error.
    How can I convert a max physical cam into a old style vrayphysicalcamera?
    thanks
    In 2016 you'll either have to create a standard cam or a vraycam and match the FOV of the physical cam. Then you can downsave to 2014.
    Keep in mind the exposure will be slightly darker as the ISO formula between VRayCAM and Physical use a different standard.
    Kind Regards,
    Morne
      thanks, sure but sometime you have to deal with case that you don't handle from the beginning. That's why I'm looking for a solution, in case there is one.
