VRay and maxscript issues
  • VRay and maxscript issues
    I don't know how to deal with these properties:
    #adv_irradmap_saveFileName, #adv_irradmap_autoSaveFileName, #caustics_saveFileName, #caustics_autoSaveFileName, #photonMap_saveFileName, \
    #photonMap_autoSaveFileName, #output_splitbitmap, #lightcache_saveFileName, #lightcache_autoSaveFileName, #includeListOverrideMtl, \
    #excludeListOverrideMtl, #excludeListRenderSubset, #includeListRenderSubset
    if I getProperty it returns undefined which is fine but if I setProperty to undefined it returns a lot of errors...
    How to deal with them without going specific to each?
    I am hoping for example of how to use them...
    Thanks.
    I will try to help with this.
    These are file paths and require string as input. Here is one example: renderers.current.adv_irradmap_autoSaveFileName="c :\test.vrmap"
    #output_splitbitmap
    I'm not sure about this one. Have to check with our developers.
    The include/exclude lists can be filled up by adding objects or current selection. Example below:
    renderers.current.excludeListOverrideMtl=$
    $Sphere:Sphere003 @ [-28.559904,14.545385,0.000000]
    #($Sphere:Sphere003 @ [-28.559904,14.545385,0.000000])
    Tashko Zashev | chaos.com
      Thank you.
      I kind of know what these properties are doing, I am wondering how to deal with them.
      for most nodes in 3dsmax I can do this:
      props = for i in (getPropNames node) collect (getProperty node i)
      for i = 1 to props.count do setProperty node (getPropNames node)[i] props[i]
      if I do that with the aforementioned properties it triggers very bad errors, with messages I have never seen like C++ shits.
      The purpose was to copy/paste VRay settings
      But nevermind I am kind of giving up on that and copying renderers.current as a maxObject...
      My next question is how do you test if VRay VFB is opened or not?
        Currently there is no maxscript command for that but we've added a feature request about it, it will be available under vfbControl() command once ready.
          This is now implemented in version 3.50.03. You can open/close and check status of the VFB window via the following commands:
          Code:
          vfbControl #show [true/false]
          Code:
          vfbControl #show
            Thank you
            Since 3.5 I actually don't need to close the VFB when setting render.current to a new instance of VRay... it used to keep the old VFB and open a new one which was annoying.
            Now it seems to work fine.
              No, still need to close the VFB and reopen it...
