Vray 3.5 Beta - Crash to desktop with IPR and matte objects
  • Vray 3.5 Beta - Crash to desktop with IPR and matte objects
    Max crashes immediately to desktop with no save dialog if IPR is running and you're changing material properties of a matte object.
    Please check the attached scene file for test. The Vray Plane object is made a Matte object through the Vray Properties. Just start IPR from the camera view and while IPR is running, open material editor and change the diffuse color of material "Floor Matte". Max will crash to desktop every time.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    Hello, Alex_M
    I was able to reproduce the crash with the scene you attached. Thank you very much! The issue is now added to our bug tracking system.
    Margarita
    Margarita Stoeva | chaos.com
    Chaos QA (V-Ray for 3ds Max)
      Awesome. By the way, I now have a scene with a matte object where just stopping IPR crashes Max (not even touching any settings in the scene). Let me know if you want me to send it too.
      Aleksandar Mitov
      96GB DDR5
        Might be the same issue I described here. Also has a matte object in the scene for shadow catching:
        http://forums.chaosgroup.com/showthr...PR-crashes-Max
          Yep, seems to be the same problem.
          Aleksandar Mitov
          96GB DDR5
            Hello!
            This is most probably the same issue, I agree. But it will be nice to check it here, just in case. Please, send the scene to margarita.stoeva@chaosgroup.com
            I apologize for the late respond.
            Happy holidays!
            Margarita
              I sent the scene to Vlado, he should have it. If you need it also, please let me know.
                Great! I think there is no need to send it again. Thank you, kosso_olli!
                I was curious about the second scene that Alex_M suggested.
                  Originally posted by Margarita.Stoeva View Post
                  Hello!
                  Happy holidays!
                  Margarita
                  I just sent the scene for inspection. Just hit render and stop the render after the Light Cache phase. Instant crash to desktop without save dialog.
                  By the way, after some more tests, it turns out it was not IPR that causes the problem. It crashes even when not using IPR. Also, the crash only occurs when using Progressive sampler. Bucket sampler doesn't cause crashes. Also if you remove all materials from the main object you don't get the crash, so it seems that the materials also play a role in the crash in addition to the Progressive sampler.
                  Aleksandar Mitov
                  96GB DDR5
                    Thank you for the scene! I'm happy to inform you that the crash doesn't seem to occur with our latest internal builds so this will be no issue in our next release.
                    If you need access to a fixed build please contact support@chaosgroup.com and send a link to this thread.
                    Margarita
                      Thanks for the info. Will try the same scene again with Beta 2.
