I'm trying to convert a very large jpg file to a tiled exr to make it more efficient. I have a memory allocation error when trying to convert using the exr tool. Is there a reason for this ? I have 32gb of memory. I tile size was set to 64 which seems very small to me. Should I be setting this higher (to 1024 or something) ?
tiled exr convertion
Originally posted by stevesideas View PostJust to let you know that the original jpg file is 627mb
Hi. The res is 50190x50190 pixels. Pretty big !
I'll upload it via wetransfer. Is your email: support@chaosgroup.com
Originally posted by stevesideas View PostHi. The res is 50190x50190 pixels. Pretty big !
No need to share the file. I'm getting the same issue here with jpg file and res. 50000x50000 on 32gb machine. Now will check on 64 gb machine and let you know the result.
Resizing the image to 40000x seems to work fine on 32gb.
This is actually a memory issue. To be able to handle such big resolution, large amount of free continuous memory is required. We can try to change the code for the EXR conversion to decrease the memory consumption for 8bit image format. Keeping the high dynamic-range for this conversions is not needed.
Can you resize this image to a smaller res. (40 000px) to complete the project?
