Did some behaviour change in the latest nightlies in regards to resizing the Vray Frame Buffer and IPR? It seems to be behaving differently.. resizing the actual render resolution?
IPR and Vray Frame Buffer Resizing
Originally posted by MattClark View PostDid some behaviour change in the latest nightlies in regards to resizing the Vray Frame Buffer and IPR? It seems to be behaving differently.. resizing the actual render resolution?
VladoI only act like I know everything, Rogers.
I can see the reasoning, is it a functionality that could maybe be turned on or off?
Personally I find myself frequently moving/resizing the VFB whilst I work, due to limited screen space and the multitude of menus/rollouts etc that can be open. Having the IPR reset everytime I do so feels counterproductive...
Originally posted by MattClark View PostI can see the reasoning, is it a functionality that could maybe be turned on or off?
Originally posted by Recon442 View PostThat was mostly me, who requested IPR resolution to be derived from VFB size. Your particular problem is caused by different issue - inability of rendering IPR inside of viewport. If you do IPR in a floating window instead of viewport, there will be always something important you need to use that VFB window is currently on top of
