VrayTriplanarTex - dark seams when bump is used
  • VrayTriplanarTex - dark seams when bump is used
    I'm getting dark seams when I use VrayTriplanarTex map in the bump slot. I also notice some slight texture distortion overall, almost like a light moire effect. As soon as I remove the triplanar map from the material tree or if I disable the bump, the dark seams and moire disappear.
    Attached below are screenshots of the results and the material. I'm on 3.57.01 nightly.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    GeForce RTX 3090 24GB + GPU Driver 566.14
    Can you post that scene so that I can take a look?
      Sure, please see attached.
      Aleksandar Mitov
      96GB DDR5
