I usually have to output final images in the rage of 4000-4500 px width/height. With such image resolutions I'm having very hard time working with Lens Effects because of the slow update speed even with turned hardware acceleration on. I'm getting update speeds of no less than 20-30 seconds every time I change any parameter. Is there a trick that allows faster updates with larger images or is my GPU just too old or slow for hardware accelerated lens effects? If I buy 2x GTX 1080 would the lens effects be faster? I'm using Vray 3.50.03.
Slow Lens Effects updates with high-res images
www.renarvisuals.com
office@renarvisuals.com
AMD Ryzen 9 9950X 16-core
96GB DDR5
GeForce RTX 5090 32GB + GPU Driver 572.83Tags: None
96GB DDR5
Have to confirm here as well, that lens effect takes a while. It actually doesnt seem very responsive after a while. I had a car with a tent (pretty basic scene) and at the beginning the lens was kinda real time, but after a while it started lagging more and more. Dont have the scene anymore, it was a test i was doing in beta but never opened a thread about it. cheers
ps. 1080p here
Originally posted by savage309 View PostAny idea how long it takes on the same image without hardware acceleration (you can turn it off from the VFB).
Best,
Blago.
I'm going to convert the scene to corona and test the lens effects in there for speed comparison.
PS: On average corona updates take 18-19 sec. with the same scene and resolution, with both bloom and glare turned on, and set to look similar to the vray render.Last edited by Alex_M; 11-02-2017, 10:11 AM.Aleksandar Mitov
96GB DDR5
For this setup hardware accelerate should definitely be (much) faster than CPU. Will test with same resolution and hardware and will update you if we can reproduce that (if we can, we will fix it).
What is your driver version ?
Best,
Blago.V-Ray fan.
Looking busy around GPUs ...
RTX ON
Thanks, hopefully it's something easy to pinpoint. My drivers are 376.33 WHQL. I should put this in my signature.Last edited by Alex_M; 11-02-2017, 10:23 AM.Aleksandar Mitov
96GB DDR5
Yes, I do use it. Unfortunately I don't ever completely disable it because the whole image becomes blurry/hazy.Aleksandar Mitov
96GB DDR5
Can you try with smaller resolution ?
With resolutions ~4k you need a bit more than 3.5 GB memory and GTX 970 is the only GPU (that we know of) that has a hardware limitation when using more than certain amount of memory (3.5GB) making it much slower. Check here for more information.
Thanks,
Best,
Blago.V-Ray fan.
RTX ON
Yes, smaller resolutions seem to update faster with GPU compared to CPU. By the way, I'm using GTX 980, not 970 (check signature). Does it have the same problem? I'm overdue for a GPU upgrade, if I get something like GTX 1080 would there be slowdowns with images of similar resolution?Aleksandar Mitov
96GB DDR5
Originally posted by Alex_M View PostYes, smaller resolutions seem to update faster with GPU compared to CPU. By the way, I'm using GTX 980, not 970 (check signature). Does it have the same problem? I'm overdue for a GPU upgrade, if I get something like GTX 1080 would there be slowdowns with images of similar resolution?
Here it seems to work fine so far.
@Alex_m - scene should not matter for this, but just in case, can you send it so we can check it as well ?
Thanks,
Best,
Blago.V-Ray fan.
RTX ON
