IPR stops on "Preparing Tone Operator" after every change
  • IPR stops on "Preparing Tone Operator" after every change
    Hi guys,
    I just installed 3.5, and am anxious to start working with all the new features. I'm most anxious about IPR, and I'm trying to work with it, however I think I'm not doing something right. Any time I make a change... either a material, or drag a new region box... IPR just stops. And at the status bar below it always says "Preparing Tone Operator". Clicking the refresh button does nothing. I can only click "stop" and then restart it. I just changed the Primary GI to Brute Force (from IRmap), but that made no change.
    Any ideas??
    Thanks!!!
    John Pruden
    Digital-X
    www.digitalxmodels.com
    3D Model Marketplace
    Hmmm.... ok, did I miss it somewhere where it says IPR works in Perspective viewports, but not in Camera viewports?? Once I switched out of my VrayPhysical Camera, IPR works as you'd expect. When I switched back to the camera viewport, same problem.
    John Pruden
    Digital-X
      Seems like it might be due to the fact that the camera was created in Vray 3.4. Now that I'm tinkering in a brand new scene, I created a camera with 3.5 and it works as expected.
      John Pruden
      Digital-X
        perhaps, wrong exposure control in the old scene?
        Lele
        emanuele.lecchi@chaos.com
        Disclaimer:
          Could be Lele. I had ran into the problem again with a new v3.5 camera. Are you thinking exposure settings in the camera? or in the Environment dialog?
          John Pruden
          Digital-X
            I'm thinking environment dialog, but really just thinking out loud.
            Any scene where it reproduces would be great as i've never encountered the issue myself...
            Lele
            Disclaimer:
              Scene please peter.matanov@chaosgroup.com
              Peter Matanov
              Chaos
                Hello,
                I think it may be the same problem I reported a few days ago in this thread.
                Nicolas Caplat
                www.intangibles.fr
                  Any news on this one" I just got the same error this morning.
                    I have come across this too, I am also getting the progress log stuck on "Building light cache"
                    Thankfully I have found a potential work around - simply hide the active camera.
                    @ Lele the following file exhibits the issue just start IPR and "building light cache" keeps flashing up in the progress window https://we.tl/KdCtOTVaud
                    Deleting and re-creating a physical camera, removing the exposure control, resetting render settings and merging into a new scene doesn't stop it.
                    Additionally if you keep hold of the left mouse button on the rendering window it will render.
                      I also experienced this problem. So far I found at least two possible causes :
                      1- Instanced camera. If the camera is instanced, IPR gets stuck and doesn't start rendering
                      2- Any kind of script or plugin that orients objects to the camera. For eg I sometimes use AVIZ A2Dimage and if I don't hide those objects, IPR also gets stuck.
                      mekene
                        Set the Lens Shifts of your cameras to 0. This is the workaround for now, a fix is coming soon.
                        Peter Matanov
                        Chaos
                          That's why Peter is QA, yes? :P
                          Lele
                          Disclaimer:
                            Hi Peter
                            Thats good news.
                            If you hide the active camera it will render and with lense shift.
                            • #15
                              This will be fixed in 3.50.04.
