3.5.03: Moving the mouse pointer over the viewport forces constant refresh of IPR
  • 3.5.03: Moving the mouse pointer over the viewport forces constant refresh of IPR
    Have a very strange problem in a scene with IPR here: When it is running, just moving the mouse over the viewport forces a refresh. It constantly does so, while moving the mouse I will be not able to see anything in IPR because of that. In the message window I get endless scrolling text while moving the mouse. Can prepare a scene if needed. If it doesn't show the problem for some reason, I can do a screencap.
    Edit: Teamviewer is also an option.
    Regards
    Oliver
    Please send me the scene at peter.matanov@chaosgroup.com
    Peter Matanov
    Chaos
      I scene will be very helpful. There are some types of objects in 3ds Max that constantly send change notification messages when the mouse moves, but it's very specific in different scenes.
        Scene was sent to Peter. Thank you!
          Peter informed me that the physical camera tilt and shift corrections are the culprit. I will try to avoid these, but I hope it can be fixed.
            So using auto correct vertical shift forces an update the whole time? Weird I don't have that afaik.
            A.
            www.digitaltwins.be
              Yes, it is the lens shift value. On a Physical Camera, mind you. When I set this to 0, the scene works fine again.
