VFB Lens Effects - Glare Mask
  • VFB Lens Effects - Glare Mask
    I have difficulties to use Glare Mask option smoothly ... Object ID and Material ID still don't seem to work ?
    To summarize my tests:
    - no Glare Mask -> OK
    - Intensity mask -> OK
    - Object ID mask -> no more Glare
    - Material ID mask -> no more Glare
    - Intensity + Object ID -> same result as Intensity mask alone
    - Intensity + Material ID -> same result as Intensity mask alone
    Anything I'm not doing right ?
    Thanks for any help
    Regards.
    Nicolas Caplat
    www.intangibles.fr
    There seems to be a problem with Intensity + other masks, but Object ID and Mtl ID should be working fine - can you send me an example scene with your issue at peter.matanov@chaosgroup.com ?
    Peter Matanov
    Chaos
      Good morning, Peter.
      I'll try to find some time to send you a stripped down version of the scene I tested v3.5 with. Thanks
      Nicolas Caplat
      www.intangibles.fr
        Hello Peter,
        Email sent !
        Regards.
        Nicolas Caplat
        www.intangibles.fr
