VFB keeps jumping to effectsresult
  • VFB keeps jumping to effectsresult
    Hi all
    It's been happening since 3.5 (all versions)
    My VFB keeps on jumping to the effectsresult, even though I don't have any lens effects in there. I have to manually switch it back to RGB color with every render
    Kind Regards,
    Morne
    Hi Morné, the effects result includes all post-processing results either from lens effects or the denoiser. Do you have denoiser with setting different than "Only generate render elements"?
    Alexander
    Alexander Kazandzhiev
    V-Ray for 3ds Max developer
      Alexander
      That was it thanks. I had it on show result result. But, why was it decided to change it? It worked fine the way it was initialy implemented. Now the only way to get a denoiser channel and a rgb channel, is to set it to "Show Result", but then it jumps to effectsResult at the end. It's a bit annoying
      Kind Regards,
      Morne
        It didn't really - the lens effects were not applied on the denoiser element.
          Fair enough, but why couldnt it stay and work like it just, and then just add a new element where the denoise and lens effects are in, but not jump to it afrter the render?
          Or at least, a settings to jump to it, or not to jump to it
          Region tests now aren't usable, because the rest of the image is cleared everytime it jumps to the effects
          Kind Regards,
          Morne
            I actually like that. I tend to toggle back and forth, from alpha to end results, but I see your point. I don't do a lot of region renders.
            Bobby Parker
            www.bobby-parker.com
            e-mail: info@bobby-parker.com
            phone: 2188206812
            My current hardware setup:
            • Ryzen 9 5900x CPU
            • 128gb Vengeance RGB Pro RAM
            • NVIDIA GeForce RTX 4090 X2
            • ​Windows 11 Pro
              Thank you for pointing this out. It's forwarded to our developers now.
              Margarita
              Margarita Stoeva | chaos.com
              Chaos QA (V-Ray for 3ds Max)
                You can actually set the "Post effects rate" setting in the System tab to 0, in that case the effects will be updated just once, when a full render completes. Let me know if this helps.
