RT GPU - VrayCompTex in bump
  • RT GPU - VrayCompTex in bump
    Hi
    The docs says its partially supported. Which part is supported?
    I have it in a bump, with a EdgesTex for round cornders, added to a normal bmp for the actual bump.
    The comptex doesnt seem to be working at all. Neither the round corners or the actual bump
    Kind Regards,
    Morne
    Try with setup like the attached one (you can put the map you like instead of noise).
    Best,
    Blago.
    V-Ray fan.
    Looking busy around GPUs ...
    RTX ON
      Thanks, that will work
      Kind Regards,
      Morne
