Hi
I've tried to use IPR today in real interior project it was really great and beyond my expectation ! (Thanks for the team )
but I found some small issues with updating the IPR that I would like to report and sorry if it has been mentioned before :
1-adding object to exclude list in override material
2-isolate light then exit isolate mode
3-render hidden lights check /uncheck
4-changing Burn Value
5- changing render resolution
All the previous require ether refresh or even normal render before IPR can update
I have faced only 2 crashes with ipr too (which is really good after 8 hours runnung ! ) when I do the following :
1-select mesh light
2-add edit poly to the original mesh in the stack
3-select polygon mode and try to move all polygons ..doing this couple of time and max will crash
this crashed my max twice but sometime it doesn't so if you couldn't re-produce it I can share the light mesh if that would help .
1-select mesh light
