Can not use Use camera path and Fly-through
According to the screenshot this camera animation is quite long 001 - 1230 frames. Have you tried to increase the Light cache subdivisions? If not please perform a render region test with 2000 for an example. Furthermore you can try even with brute force / brute force to see if those artifacts will disappear.
What is the V-Ray/Max version?
Do you get any errors or warnings in the V-Ray log during this render?
The problem still exists, I am using v-ray 3.5.04, this is a bug, I have encountered the same problem before, it exists in many scenes, I have sent a wrong scene to Vlado, but he did not reply I waited for a long time still did not reply to me. Now my clients are complaining about the programs I have given them out. what should I do?
Also keep in mind that with the newly introduced sampling and with the optimizations made in the latest version you should get very good render times even without the usage of LC pre-calculation (Use camera path and Fly-through mode). Furthermore for that animation length you should use a lot of subdivs. In case that you want to use 1000 subdivs per frame, if you multiply that number to 1230 frames that will be very large number. Generally the fly-through method is not a very good choice for long sequences.
Our suggestion will be to disable Use camera path and use Single frame mode instead.Last edited by Zdravko.Keremidchiev; 20-03-2017, 07:43 AM.
Yes, a lot faster, thanks to Chaosgroup, I will try to segment increased to 1000, and use a single frame instead of using the camera, cancel the path, even enbree acceleration has been closed, but there is still a small amount of error, because of the added noise to the processing function, so the final effect is ok! Could you tell me your e-mail address? I send the scene to you!
There are a lot of scenes in this error. Unfortunately, you have to render the entire animation scene to find out where the error is. Can you tell me how to send it to you? By email? Or SkyDrive, I uploaded to China more commonly used server you can download it? For example: Baidu cloud?
I assume this thread (https://forums.chaosgroup.com/showth...he-next-update) is related to this issue?
Send us your scene to support at chaosugroup.com
It will work fine if you set the light evaluation mode to "probabilistic" or "full". Increasing the light cache subdivs should also help. In any case, it would be very helpful to look at your scene.
VladoI only act like I know everything, Rogers.
I would like to know the next version can solve the following questions: 1. does not support Use Embree, check it will appear shadows, 2. can not use Use camera path, use it will also appear black block, can not use Fly-through, this is Very urgent need to solve the problem. Rely on Light cache subdivision to improve the problem, the speed becomes very slow, it is unwise choice.
The support for Use Camera path (LightCache) and Fly-through mode will remain in the new versions. I suggested not using those because of the length of the animation and the new optimizations in V-Ray. It will be up to you to decide whether to use it.
Still if you have issues with those send us the scene and we will have a look at it.
Scene has been sent to your mailbox support@chaosgroup.com, thank you! Ticket number is: #836833.
