EffectsResults
  • EffectsResults
    I have a VFB that isn't updating the effectsResults. It jumped to it and after I toggled to RGB and back, it stopped updating.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090
    • ​Windows 11 Pro
    Turning off hardware acceleration and forcing an update worked, however, that's for bloom/glare. The VFB isn't updating for the Denoiser either.
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      Check what is the post effects rate set to under system. If it's 0, it will only update at the END of the render
      Try setting it to 10 for more updates in between
      Kind Regards,
      Morne
        Nope, it is set at 10. I have moved on, so I'll see if it happens in this new project.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          Which V-Ray version is this? Can you reproduce this behavior on a simple scene?
            If you use bucket rendering, the effectsResult will update only after the entire image is complete (or you change some lens effects setting). It should update regularly when using the progressive sampler though.
              Yes, that was it, thanks.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
