Some buckets lose Lighting info
  • Some buckets lose Lighting info
    Hello,
    please look at my problem here using Adaptive Lighting = 16.
    Sometimes a random render slave loses the Lighting info, but only inside a few buckets.
    It does not happen using full light evaluation.
    Vray 3.50.04
    Res. 800x600, BF+LC (LC 600, all defaults, per frame)
    White preview Animation, MSR=6, Bucket mode, Noise Treshold 0,05 + denoiser
ID:	887280Click image for larger version
    Here is a download link with three packages of 100 Frames
    https://www.dropbox.com/s/irqtvp2q83...rison.zip?dl=0
    Kind regards
    Alex
    Just discovered I am having a same problem, the render have some dark squares and when I check on the light select element, I can see the error.
    I'm now trying to render it in strips.
      just render tis last night.....Click image for larger version
        Can someone send me a scene for this at peter.matanov@chaosgroup.com ?
        Peter Matanov
        Chaos
          thanks peter,
          After a long eliminating process, it was a set model with normal maps and with sss materials.
          cheers
