IPR problem with blended box map
  • IPR problem with blended box map
    Max's own BBM doesn't work properly with the IPR.
    The mapping shifts as soon as you enable the IPR.
    See sample scene. Render normally. Engage IPR and watch the map move.
    It seems to be fine!
    Regards,
    Ledian
      It seems identical here as well. Which V-Ray version are you using? Can you attach the outputs?
        Very strange. It's completely reproducible here. I just render the perspective viewport in that provided scene. And then click the IPR button in buffer and the map changes. It's 3.50.04. Images here. It's not shifting by a lot but it's definitely shifting (or scaling). Left side is regular. Right side is IPR.
Name:	bbm render.JPG
ID:	867145Click image for larger version
Name:	bbm render ipr.JPG
          alright, I've missed that. Will make a note about it.
            [ATTACH=CONFIG]37108[/ATTACH][ATTACH=CONFIG]37107[/ATTACH]
            Seems like a bug!
            Sorry for my previous post.
            Regards,
            Ledian
              This seems to still be an issue in V-Ray Next update 3 as well (max 201.
              Shifting from IPR to Bucket renders two vastly different results (when using a large map scale) when using the native 3ds max Blended Box Map.
              http://henrikbclausen.com
                This had something to with the "Work in camera space" option in the System tab and I still haven't had a chance to look into it. The VRayTriplanar texture should work fine though.
                  Sorry to dredge up an old thread but I've just run into this same issue with the discrepancy between the IPR and production render using the blended box map. Is there any news on this?
                  I'd be all for using a VRayTriplanar texture but I've been using smoke as a blend map on the BBM and can't see how to replicate this.
                    Nothing new I'm afraid, I didn't find a way to fix it yet. But we can add the ability to use a blend map to the triplanar texture.
                      Sorry, forgot to reply. Thanks Vlado, that would be very useful.
