Hello,
I have just come across an unhandled exception in a rather special combination, that is reproducable (Vray 3.50.04, Max 2016):
- Create a box
- Create a VrayClipper, turn it to Mesh Mode, turn off replace mesh with clipper, pick the box
- Create a standard spot light, enable shadow map
- Render -> Unhandled Exception
The workaround I found was excluding the clipper from the light. The only reason I use shadow maps at all, is because the volume light effect does not work with Vray shadows.
I can use the workaround, I just want to let you know about the error and maybe save somebody the search for the problem.
Thanks,
Bob
- Create a box
Thanks,
Bob
