Frequent crashes with IPR in a particular scene
  • Frequent crashes with IPR in a particular scene
    I'm getting frequent crashes with IPR in a particular scene when copying lights, cancelling copying of lights and doing undo operations while IPR is running. Sometimes everything works fine when doing the aforementioned operations and sometimes it crashes. It seems a bit random but it does crash a 100% if I use IPR for more than 5-10 minutes and do these operations.
    I've just sent an email to support with scene and instructions on how to reproduce.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    An update on this issue. It has just crashed when I just moved one of the lights.
    Aleksandar Mitov
    96GB DDR5
      We are looking into it, but we are unable to reproduce some of the crashes. One of my colleague will get back to you shortly.
        It crashed again. This time I didn't even do anything like moving lights, copying etc. I think it crashed just while I left it rendering and not touching anything. I've sent you the minidump file as you suggested. Let me know if you need anything else.
        UPDATE: Now it crashed right after I deleted a Vray Light while IPR was running. The new minidump file is sent to support.
        Let me know if you need any more minidump files if new crashes occur. I don't want to bury you with a ton of them since I'm getting quite a lot of crashes with IPR in this particular scene.
        UPDATE2: Now IPR crashed Max when I clicked on "region render" in VFB in order to render the whole frame instead of the region. I've got a minidump of that one too if you need it.
        Aleksandar Mitov
        96GB DDR5
