Are lights handled differently between ActiveShade and Production for RT?
  • Are lights handled differently between ActiveShade and Production for RT?
    I was working with RT CUDA using ActiveShade and HDR Light Studio and got all my lights dialed in, then I switched to RT CUDA Production and the lighting looks different. I lost some shading I was after. It looks like only one light is not reacting the same, it seems brighter in production.
    Is there a difference between how AS handles lights then production?
    I turned all lights off except my hdmi dome, and AS showed more shading, production showed less shading...brighter in shadow areas.
      There shouldn't be much of a difference in this case, but without the scene it's hard to say what may be wrong.
        this has nothing to do with trace depth/max transparency level in your case, right?
        If trace depth is too low, vray will compute a fake lighting so to speak. Not a pro here, but I had some issues with that in the past and am now always dialing trace depth up, at least over 5...
        Add Your Light LogoCheck out my tutorials, assets, free samples and weekly newsletter:
        www.AddYourLight.com
        Always looking to learn, become better and serve better.
          Ok, thanks...I'll look into it more today, just thought I'd see if there was a change made in the last vray update.
            I forgot to say that I'm speaking about transparent objects, materials with refraction
              Got it. Thank you.
                Vlado,
                I just sent you the file. Thanks.
