vray clipper aliasing fix?
  • vray clipper aliasing fix?
    using the vray clipper to animate some simple booleans through a (highly subdivided) surface and getting these artifacts in my renders that I cant seem to shift
    I have tried making the geometry on both objects more subdivided but its not having the desired effect.
    Is this a limitation of vray clipper? i know this is probably not the way it was intended to be used.
    Here is a animted example of the problem
    https://www.dropbox.com/s/bgnlv16ayb....RGB_.mov?dl=0
    I had used it successfully in animation on this scene below on much simpler geometry with no artifacts or flickering (if the geometry was closed and good topology - so i was hoping it would work here as well
    Hello,
    Could you share a part of the scene for some test here?
    Yavor
    Yavor Rubenov
    V-Ray for 3ds Max developer
