Vray RT Deadline error
  • Vray RT Deadline error
    Hi, not sure if this is a vray problem or a max or deadline problem.... but hoping someone could help.
    Getting this 'MAXScript Rollout Handler Exception' when trying to submit a vray rt job to deadline. See attached jpeg.
    Any ideas whats happening here and how I might fix it?
    Using Vray 3.50.04 and deadline 8.0
    This seems like a Deadline issue and it would be best to report it to Thinkbox.
      You can also try and do a clean install:
      Uninstall V-Ray. After that , please check if there are any script files left in "C:\Program Files\Autodesk\3ds Max XXXX\scripts\startup" that have names starting with "vray" (i.e. vrayutils.ms, vrayinstall.ms, vraysceneexport.ms vraylightlister.ms)
      and "C:\Program Files\Autodesk\3ds Max XXX\scripts\V-Ray". If there are such files please remove them.
      If that doesn't help you should contact Thinkbox.
        Thanks Zdravko, I tried the clean install but unfortunately this didn't help. I will contact thinkbox and see if they know what the deal is.
        My guess is that it is an Autodesk issue... which means I will probably never get an answer!
