Extreme water reflections with bump map
  • Extreme water reflections with bump map
    I'm trying to make a pond but I'm getting some really strange reflections in the water when I put a Noise map in the bump slot (bump strength is 20). All render settings are default. The sun light and sky map also have default settings. Please check the image below. Also some buckets don't seem to render the bump (marked with red). I'm using Vray 3.50.04.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    Have you tried turning the sun visibility off?
      Not really, I want to keep the highlights from the sun visible in other objects. It's only the highlights in the pond that turn out strange. Anyways, I played with the material a bit and I managed to craft a better shader and I avoided the strange highlights. You can see in the image below. I think that what helped most was turning down the bump to 2-3. There are no bucket artifacts now too which was my main concern. Click image for larger version  Name:	water_reflections.jpg Views:	1 Size:	174.5 KB ID:	954692
      Aleksandar Mitov
      96GB DDR5
