waving form modeling
  • waving form modeling
    I am currently working on project full of waving form, is there any method to model that correctly and easy to edit for further render?
    The result should be something like this:
    Thanks
    There is a wave spacewarp you can use for modeling.
    AMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
    2D | 3D | web | video
    jiri.matys@gmail.com
    https://gumroad.com/jirimatys
    https://www.artstation.com/jiri_matys
    https://www.youtube.com/channel/UCAv...Rq9X_wxwPX-0tg
    https://www.instagram.com/jiri.matys_cgi/
    https://www.behance.net/Jiri_Matys
    https://cz.linkedin.com/in/jiří-matys-195a41a0
      Thanks! But can I use that to do a circular organic form of the image above showing?
      Didn't find much information over the internet.
      Thank you!
        Create a cylinder with enough cap segments. Delete the top polygons. Add a ripple modifier. Profit
        A.
        www.digitaltwins.be
          Thanks!! I can create the form now but how about the texture and the lighting map? to create that fading led dots effect?
          I tried to use a bitmap with illstration for that but it looks fake. What modifier or material should I use for that?
          Can I use particle system for that? But I am doing a still image rendering.
          Thank you!!
            Thank you!!
            Use forest pack or something similar to distribute a bunch of sphere's with a vraylighmtl or something. You can use the grid distribution map from Forest Pack. I've attached my scene to this. (Max 2016)
            Click image for larger version  Name:	RippleDot.JPG Views:	1 Size:	281.5 KB ID:	956297
            A.
            www.digitaltwins.be
              Clovis Gay has some kickass plugins, one is called UI Toolkit. Might help... http://hocuspocus-studio.fr/tools/product/ui-toolkit/
                I think their site may be down, just tried your link and then googling it and going that way and both wont connect...
                Cheers,
                -dave
                ■ ASUS ROG STRIX X399-E - 1950X ■ ASUS ROG STRIX X399-E - 2990WX ■ ASUS PRIME X399 - 2990WX ■ GIGABYTE AORUS X399 - 2990WX ■ ASUS Maximus Extreme XI with i9-9900k ■
                  I have downloaded the forest pack and installed it. It worked perfectly in the viewport but didn't show in the rendering. Anyone had this issue before too?
                  Thanks
                    Thanks
                    Did you apply a material? What versions of vray and FP are you using?
                    A.
                    www.digitaltwins.be
