3dsmax / VRay 3.6 / Cryptomatte / Separate render channels
  • 3dsmax / VRay 3.6 / Cryptomatte / Separate render channels
    I started using Cryptomatte for VRay today, no problem with the VRay raw image file option, I'm saving exr files and it works perfectly but 3dsmax crashes when using VRayCryptomatte render element and separate render channels option together.
    Am I missing something ?
    Thanks,
    Julien Donadille
    Render/Compositing TD at Backlight Studio.
    Same problem
    Please fix at 3.60.02.
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
      We'll fix it.
      Peter Matanov
      Chaos
        thanks !
          Can someone offer some insight on how to make this work with Nuke? I have the Nuke side implemented and working with the sample images from Psyop, but it seems that it does not register the cryptomatte render elements. Is there an option that I'm missing?
          Update: Didn't realize I had to save it through the VRay Raw Image dialog box, not the normal Max Common Options Save Dialog. Works fine now.
          Last edited by hooperized; 30-06-2017, 03:08 PM. Reason: Realized I was using the wrong save dialog
          Sean Hooper
          Director of VFX
          Synchrony Studios
            Glad you figured it out, will make a note about this in the docs.
