VRay DR and Forest Pack
  • VRay DR and Forest Pack
    I had installed Vray 3.60.01 and Forest Pack Pro 534b.
    I have two workstations (Win7) and in DR they are ok.
    On my render nodes (Win XP) the Forest objects don?t show up. I think it was a problem of paths and then i modify the 3dsmax.ini on render nodes. A no go? after some test, I verify that VRay DR modifies the render nodes 3dsmax.ini and the paths of Forest pack are removed?
    I need help? In previous versions, all work
    Thanks in advance
    Nicolau Pais www.id3d.pt
    My current hardware setup: HP Z820 32-Core Dual E5-2670 128GB RAM - NVIDIA® RTX 3060
    Hi, Nicolau,
    The right Fp version for 3.60.01 is Forest Pack Pro v5.4.0. Normally V-Ray does not modify 3ds Max's .ini files directly, excluding for the plugins.ini only during installation, can you show me the proper and the modified files I would like to compare the changes? Because this file is located "C:\Users\sasho\AppData\Local\Autodesk\3dsMax\ 2018 - 64bit\ENU\3dsMax.ini" I suspect that 3ds Max updates it anyway.
    Alexander
    Alexander Kazandzhiev
    V-Ray for 3ds Max developer
      Maybe set the file to read only?
