I'm experiencing some crashes when rendering a high res image 8000x4000px on a machine via backburner.
I'm not sure what is causing it. The file uses a lot of memory so I have to render on this machine which is set up as a rendernode only.
Any advice on what I should try?
I've rendered some earlier versions of the image successfully, but with less foam and splash particles. Then the render finished and VFB wrote the output files to disk, but max still crashed after writing the files and backburner would mark the job as failed and restart try to restart it several times. But now (with more foam in the sim), 3dsmax seems to crash in the middle the of rendering process.
