Can't load render settings from VFB history if I switch from Adv to RT, then back to Adv again
  • Can't load render settings from VFB history if I switch from Adv to RT, then back to Adv again
    So I'm rendering an image with Adv, saved it to VFB history and then I switched to RT to check something. I then switched back to Adv and tried to load the render settings from the saved image. It didn't work. Settings were still at default.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    On our side everything seems to be working fine.
    Wich version of V-Ray and 3dsMax are you currently using?
    Does this issue occurs on a spesific scene or on every new one?
    Does a spesific setting could not be loaded or all of them?
    Does this issue occured only once or you could still reproduce it?
    Nikolay Kusht | chaos.com
    Team Lead, 3D Support | contact us
      After further testing we managed to reproduce the issue here. This issue was reported as a bug to our system and we will inform update this thread when we have progress on it.
        Great, thanks.
        Aleksandar Mitov
        96GB DDR5
