Fog Problem
  • Fog Problem
    Hi all,
    i would like to create a beach scene and at the very first step i have the following problem. i created a ground and a simple plane as a water surface.
    When i set the fog color for the water material there comes a dark blue stripe between the water and the beach. only when i set the fog multiplier to zero i have not this issue. and it doesnt matter wich multiplier value i use, the stripe is always the same.
    anyone know what the problem is?
    N
    Hello!
    You can avoid this by adjusting the shadow bias parameter in VRaySun. Try some low value like 0.01
    Margarita
    Margarita Stoeva | chaos.com
    Chaos QA (V-Ray for 3ds Max)
      Hi Margarita, many thanks for that tip. It solves the problem.
      best regards
      Nick
