VRay Fur Disappears When Opening Scene
  • VRay Fur Disappears When Opening Scene
    Hi all,
    We're having an issue when using VRay Fur. I've got a couple of different maps in the Length, Density and Bend Direction slots, if I reload the maps then it renders fine. The issue is when I reopen the scene and render it the fur doesn't render. The only way to fix is to click Reload on the maps, obviously this means that rendering on the farm won't work though.
    I've created a simple scene using the same textures and attached it. It may be that I'm not using the maps correctly in these slots so please advise.
    Thanks,
    Max
    Freelance 3D Generalist
    www.maxwood.co.uk
    I see you are on 3.50.03, can you update to 3.50.04 or even better 3.60 ? We have a few fixes related to the V-Ray Fur there.
    Tashko Zashev | chaos.com
      Originally posted by tashko.zashev View Post
      Probably not. As a freelancer I think it's out of my control unfortunately, it's a large studio and we're mid project. Could you confirm whether updating will fix it though? I can try and suggest it if so.
      www.maxwood.co.uk
