Frame buffer Display problem
  • Frame buffer Display problem
    Hi all,
    Since i have update to Max 2018.1 and Vray 3.60.02 the frame buffer don't refresh the display of the bucket during the render in production mode meanwhile it works in network rendering on the same PC.
    See screenshot below
    If anyone could help me it would be great.
    If you turn on the low thread priority option in the System tab, does it get better?
      Hi Vlado,
      I turn on the low thread priority option but it doesn't change anything.
        Ok, what if you right-click on the 3dsmax.exe process in the Task manager and set the process priority to "Below normal"?
          I tried to set the affinity with 2 CPU Core less and to set the priority to below normal but it don't works.
          I have the same problem on another PC in the office wich have a two XEON CPU but it have the same problem
          My scene has been made under Max 2017 can it be the problem ?
            with Vray 3.5
              i have tried to uninstall Max2018 et Vray and reinstall the both this afternoon but it dosn't solve the problem
                I saw that Bruce Hart had post a topic with a similar problem yesterday with the frame buffer
