Can someone confirm that they can get RT hybrid mode to work across distributed rendering on a Ryzen cpu? I can't seem to figure it out. I have enabled it through the "select devices" menu, and it also works when I render locally on the Ryzen machine. But when I try to use it through DR nothing happens. The GPU in the Ryzen system renders as it should, just not the CPU. I checked the Firewall and couldn't see any problems there. My other machine with an i7 renders fine utilizing the CPU through DR.
I'm on Max 2014, Vray 3.60.03. All systems are Windows 7 except for the Ryzen which is Windows 10.
Edit: Standard CPU RT engine works fine with the Ryzen over DR. Just not hybrid.
