VrayClipper Bug
  • VrayClipper Bug
    The VrayClipper only uses material ID 1 when clipping through a multi sub object material, instead of using all the ID's that make up the object so when it's sliced you only see material ID 1 on the capped faces which is not what it should be. Can this be fixed?
    Cheers.
    Hello,
    This is by design. For such cases the clipper has an option to override the material ID with an ID you specify.
    Yavor
    Yavor Rubenov
    V-Ray for 3ds Max developer
      Thanks Yavor for getting back to me, the problem is that If I set an ID it still uses 1 ID whether it be ID 1,2,3 etc.. I need it to slice and show all the ID's it's cutting through else it just looks weird.
      For example, if I have mobile phone model which is collapsed into a single mesh and I have all the material ID's applied to it, I don't want o choose an ID because if I do it will show one material on the capped faces, whereas in reality, you would see multiple materials, such as glass, plastic and metal etc.
      Cheers.
        I understand the issue you have with a model collapsed into a single mesh.
        Unfortunately the clipper itself is a render time effect and it works on the rays traced by V-Ray not on the geometry itself. Rays can come from any direction so the clipper can't determine which face it is clipping - it can only determine if it is inside an object and which object.
        To get different materials on the different parts - they need to be different scene objects - then the clipper can use their materials.
        Yavor Rubenov
          Okay, that's a bit unfortunate, but makes sense.
          Cheers.
