Vray mesh export problem
  • Vray mesh export problem
    Hi, i have a big issue with vray mesh export. When i try to export multiple object with option "export each selected object in a separate file " an error occurs : "there was an error creating the .vrmesh file for node [VUtils::subdivideMeshToFile] cannot create file.
    Anyone can help? I can't even export a single object with this option enabled....
    Best regards
    B.
    https://www.mofo-archviz.com/
    Not sure about the error specifically, but I sometimes have to reset XForm and centerpivot()
      A possible cause might be if the directory you're exporting to doesn't exist or is not accessible for some reason.
      Is the export actually working fine if you switch the export from multiple to a single vrmesh file?
      Miroslav Ivanov
      Chaos Cosmos
        Yes, it's working fine when i export to a single vrmesh...
