No file stream error - rendering very large image
  • No file stream error - rendering very large image
    After 20 hours rendering a really large image (I followed the instructions from Vray documents for rendering very large images) I gert this error at render end. (please see image attached)
    No .vrimg is saved and I havent found a solution yet.
    Does anyone experienced somehing similar?
    jerocg.com
    Are you rendering to a network drive directly, or to a local drive?
      Have the same error, but rendering 4000x2000 image... Rendering into VRImg format, as when I'm using VFB - the system just completely freezes. Windows 10x64, 3dsmax 2016, VRay 3.60.01, 16GB Ram.
      I tried to save in to EXR format - no error, but no file as well.
      Updated to 3.60.03 - same error, same missing file with Exr.
      SOLVED :
      Turned off denoiser element. I think it's a good idea to check whether the image is in the memory buffer to denoise or it is not.
      Available for remote work.
      My LinkedIn: https://www.linkedin.com/in/olegbudeanu/
        Ok, thanks - will look into it.
