Normal Maps override VRayDisplacement
  • Normal Maps override VRayDisplacement
    We're having an issue where having a normal map in the material overrides any displacement detail. So in this example most of the detail comes from the displacement and then we are using normal maps to add fine surface details. As soon as it's turned on the normal map completely wipes out all the information in the displacement map, even though it still shows in the VRayNormals pass. At first I thought it was an auto bump issue but turning on cache normals, view dependant off and setting the edge length extremely low gives the same results.
    David Weaver
    Senior "Belief Crafter"
    Realtime UK
    https://www.artstation.com/artist/weaver
    Can you attach an example scene
      Here you go. Thank you.
      David Weaver
      Realtime UK
        Thank you for sending the scene, the issue is in the bug tracking system. As soon as we get any update from the developers I'll let you know.
          That's great, thank you. We did some extra tests and it all works as expected when using the old max 'Normal Bump' texture.
          David Weaver
          Realtime UK
            This will be fixed for the next 3.6 stable build tomorrow.
              Brilliant, thank you.
              David Weaver
              Realtime UK
