Compiling Geometry
  • Compiling Geometry
    I have come across another scene that just sits at compiling geometry. If I delete the object it is stuck on it'll just get stuck on the next thing. I reset the scene and collapsed everything, but it still gets stuck. I read other posts about this and they all have gone unsolved. Is there a solution for it and what is causing it?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    It was a Wall & Tile material
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      Glad you got it sorted out. I may be mistaken but it often feels to me as if the render dialog is displaying the last successful operation and when it does get stuck it's not showing what it really got held up on.
        I've noticed that too and I hope Chaosgroup do something about it.
        Simply, I love to put pixels together! Sounds easy right : ))
        Sketchbook-1 /Sketchbook-2 / Behance / Facebook
          It would help if you can get me a scene to vlado@chaosgroup.com to confirm if we have fixed it.
            Here is a screen recording of what happens. I have to kill MAX.
            https://youtu.be/Vk_5lJzNae0
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              Yes, I believe you But I still need the scene.
                Will do, when I get a chance. It isn?t a consistent issue, but maybe you can reproduce it.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  Maybe you forgot to tick off the displacement map in the material itself.
                  A.
                  www.digitaltwins.be
                    As Vizioen said. 90% of the time, when V-Ray is stuck on compiling geometry it is because there is a material with displacement active.
                    mekene
                      I did indeed have a Walls&Tile material with displacement enabled. I thought I checked that, but I guess I missed it.
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                        The part that frustrates is you can't cancel, you just have to wait or kill MAX.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          have almost same issue with compiling geometry and static embree accelerator - tooks a lot of time and hanging for a while ...
                          nothing special in the scene ,,,
                            in my scene freezes of compiling and embree caused by doors/windows , weird, geometry is ok, collapsed editable poly + uvw map (multi sub material)
                              I'm experiencing the same issues I have to kill max and sometimes even when I delete the object that causes the probleme, the scene still hangs while compiling geometry,
                              I'm currently 'cleaning up' a scene, object by object, that's giving me the exact same problem after importing a couple of plants/forests that render fine in other scenes, its really annoying.
