Refraction/Reflection of MatID seems to be broken in vray 3.6
  • Refraction/Reflection of MatID seems to be broken in vray 3.6
    HI,
    could it be that the refraction and reflection of MatIDs is broken in vray 3.6 ?
    I used it some time ago, cant remember which version of vray it was, and there it worked like a charme.
    Below is my setup. maybe I mixed something...
    Thanks for any help,
    Markus
    PS: I also tested it in a new file and got the same problem.
    MBA Studios | 3D Images & Visual Effects
    It looks it works fine here with 3.60.03.
    Here is my attempt to rebuild that scene: http://ftp.chaosgroup.com/support/scenes/multimatte.max
      hmmm, ok i was using the VrayMtlID RenderElement. There it doesnt work. With the MultiMatte it works.
      Any reason why the dedicated Vray render element isnt working?
        It's an integer render element and we can't propagate it. I think there is an option to treat the values as colors and then it should work.
          here is the option and it works.
          Martin Minev | chaos.com
