Render region is present! (Do not show again button not working)
  • Render region is present! (Do not show again button not working)
    Hello,
    We encounter an annoying bug when trying to render using Render Region. The "Render region is present!" window appear even if we check "Do not show again." button.
    Does someone know a solution for this?
    Looking forward for an answer.
    Best Regards,
    George
    This should be fixed for the latest 3.60.03.
    Are you using that or earlier version of V-Ray?
      Thank you for replying.
      We are using 3.60.03 and it still happens. It is something that we can do?
      Best,
      George
        It's fixed in the stable nightlies, sorry for the wrong info. If you need an access to them, write to support@chaosgroup.com pointing to this thread.
        Peter Matanov
        Chaos
          I understand, thanks for replying. We will wait for the new Vray update then.
          Best,
          George
