3dsmax 2016 vray script errors on startup
  • 3dsmax 2016 vray script errors on startup
    Seem to be related to these 3 items:
    macroScript VRayRTAnimPreview
    macroScript VRayDisplacementMod
    macroScript VRayLightLister
    I've tried deleting 3dsmax.ini and plugins.cfg but neither works.
    Regards
    Steve
    My Portfolio
    Hello,
    What errors are you getting - can you for example make a screenshot of the error messages.
    One thing that happens from time to time is that MAX caches the installed MAXScript files to one of its folders and sometimes that cached files get messed up. If that is the case - you can simply delete the cached files. They are often named temp_Something_.mcr but the exact name can be seen on the error message.
    Yavor
    Yavor Rubenov
    V-Ray for 3ds Max developer
      Try deleting the ENU folder("C:\Users\%username%\AppData\Local\Autodesk \3dsMax\2016 - 64bit\ENU"). Also, you could try deleting the "maxstart.max" if present ("C:\Users\%username%\Documents\3dsMax\scenes\maxs tart.max").
      Nikolay Kusht | chaos.com
      Team Lead, 3D Support | contact us
        I just deleted the folder you suggested and it seems to have worked. Cheers
        Regards
        Steve
        My Portfolio
