Render Mask VFB not clearing after each frame
  • Render Mask VFB not clearing after each frame
    We ran a animation with Render Mask include/exclude enabled. There was only one object added to the include list. What seems to have happened is that the VFB wasn't clearing after each frame so we would have that object overlapping itself in subsequent frames. Thoughts?
    Neal Biggs
    3D Generalist | Freelance | Founder | Big5 Studio
    http://big5studio.com/
    3ds Max 2022 - V-Ray5 Update 2.2
    Hello
    There is an option what to happen with the previous VFB image in animations - the default is "Unchanged" so the object is overlapping. If you set it to "Clear" - it will clear after each frame.
    https://docs.chaosgroup.com/display/...ncedParameters
    Yavor
    Yavor Rubenov
    V-Ray for 3ds Max developer
      Thank you! I was looking for that
      Neal Biggs
        Originally posted by yavor.rubenov View Post
        Hello
        Yavor
        Where in the UI do I find this option? The link you provided has gone dead. I'm still using Vray Next.
          ... I found it now, under settings -> system, but very well hidden! You have to turn on "advanced", and the drop-down window is unreadable.
            It would be nice if by default it could be cleared for animations, while for stills it is probably more practical to keep the unchanged option.
              Yes! And ideally you have one setting for Animation and one Setting for Stills. These would be saved with the scene, but default to clear for animation, saved for stills.
                Weird, but I just rendered an entire animation with rendermask, and even though this setting was set to clear, the subsequent frames are trailing in the transparent areas during the entire animation. I use V-ray 5.2 in Max 2021.
                The animation was submitted to Backburner, but the setting should follow the file right?
                Can anyone confirm if it is working or not?
                Click image for larger version  Name:	VFB_not_cleared_Screenshot 2021-11-09 091825.jpg Views:	0 Size:	39.0 KB ID:	1129914
                This is how it turned out.
                Click image for larger version  Name:	image_68145.jpg Views:	4 Size:	55.3 KB ID:	1129915
                This is what it should have looked like.
                Click image for larger version  Name:	VFB Clear Screenshot 2021-11-09 091740.jpg Views:	0 Size:	27.4 KB ID:	1129913​​
                My settings
                Last edited by markus_s_cg; 09-11-2021, 01:32 AM. Reason: Edit because of duplicate attachments
                  My settings
                  Ah, I just saw that this issue is fixed in the Hotfix! Never mind then... Thanks for releasing the hotfix so quickly!
                    Yep it is in the hotfix. Sorry again for the inconvenience.
                    Yavor Rubenov
                      The issue seems to be happening again. I am using Max 2022 with Vray 5 Update 2 and the same thing is happening for me. It is set to Clear after the frame completes and I'm using Object IDs as a render mask:
                      Please advise.
                      Thanks
                      Jim Lammers
                      Trinity Animation, Inc.
                      www.trinity3d.com
                        Please advise.
                        Thanks
                        Have you installed the hotfix?
                          Ah, sorry, I was confused, I thought the Update 2 was what you guys meant when you referred to the hotfix. Yes, after installing the hotfix the issue is fixed. Sorry for the confusion.
                          Thanks
                          Jim Lammers
                          www.trinity3d.com
