Volume Grid Instances
  • Volume Grid Instances
    Hallo I have a problem with vray volume grids. I need to do arrays of fire and I would like to use instances of one volume grid, so I don't need to edit very grid (20-50 grids) when change timing or rendering options.
    But when I instance a volume grid, only the first created instance is rendered.
    Thannks for your help.
    Dietmar
    www.dk-vision.de
    Hello!
    Unfortunately VRayVolumeGrid instancing is not implemented yet, like discussed in https://forums.chaosgroup.com/forum/...023#post785023
    With a little luck you may have some results with the mesh modes but it's not expected to work at this point in general.
    Margarita
    Margarita Stoeva | chaos.com
    Chaos QA (V-Ray for 3ds Max)
