vraydistancetex + slow file
  • vraydistancetex + slow file
    when I use vray distance texture on a scene, the files becomes really slow to work, specially when editing geometry that is affecting the distance texture. The slowdown occurs when opening the file too.
    is this a normal behavior?
    thank you!
    Surrealismo
    https://www.facebook.com/surrrealismo
    how can I get attention from support?
    Surrealismo
      Hello,
      It would be best if you could send a scene with this problem to our support (support@chaosgroup.com).
      In V-Ray Next Beta 1 there are some major improvements to the rendertime performance of the distance tex and the viewport performance is also a bit better. Having a problem scene could help us make things even better.
      Yavor
      Yavor Rubenov
      V-Ray for 3ds Max developer
        hi Yavor, email sent! thank you!!
        Surrealismo
          Thank you for sending the scene. The files are now in our bug tracking system. We will investigate further and get back to you.
            i'm interested in this too as I'm working at the moment with similar case ( unfortunately I don't have the permission to share the files)
            Simply, I love to put pixels together! Sounds easy right : ))
            Sketchbook-1 /Sketchbook-2 / Behance / Facebook
              Zdravko.Keremidchiev have you had any findings?
              Surrealismo
                The issue is not addressed yet. I increase its priority so the developers could get to it sooner. Keep in mind that its a bit slow around the holidays.
                  ok. that?s understandable. thank you
                  Surrealismo
                    The distance texture won't slow down 3ds max anymore. The fix will be part of the next 4.0 beta release.
                      thanks, but,i?t won?t be fix on vray3?
                      Surrealismo
                        We will try to add it to 3.x too.
                        Peter Matanov
                        Chaos
                          thank you peter, we really appreciated that. we are still in 3 and we are facing this slowdown everyday and it?s a nightmare.
                          Surrealismo
                            It's in the stable nightlies.
                            Peter Matanov
                            Chaos
