Rendering large (Vrimg) file - no stream output - (RIFile::WTVrayInfo) No file stream
  • Rendering large (Vrimg) file - no stream output - (RIFile::WTVrayInfo) No file stream
    Hi
    rendering a large file, done all the setup as per instruction BUT no data is output (RIFile::WTVrayInfo) No file stream, unless I turn on the Memory Frame Buffer, which sort of defeats the object ?
    Any suggestions ?
    Thanks in advance
    Spike
    Do you have V-Ray Denoiser involved in this setup ?
    Tashko Zashev | chaos.com
      Hi
      Turned it off and it seems to work (BUT I have just rendered a smaller resolution, to try it out).
      I will try a larger resolution later.
        Denoiser is disabled automatically when setup a render without VFB in the Next beta
